2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
Rikachu
Morning all! Which sky remote code do people recommend for use with the x85c? The one I'm using now isn't the best option... The arrow buttons on the sky remote act as "confirm" buttons so I can't navigate the home menu nor select HDMI channels (unless I cycle through them with 'help'. Any advice much appreciated!
Tags (3)
lebarry
Anyone who has purchased one of the Sony 2015 Android TVs should read the article/review on the enclosed link. I think in my opinion it just about sums up the frustrations those of us that has purchased one are going through. It certainly would be no harm if Sony also read the article and learned from it. http://www.trustedreviews.com/sony-android-smart-tv-system-2015-review
kelchashock
Do you know when the next update is out? The most annoying thing is that sound cuts off intermittently and the tv emits a buzzing noise. I have to reboot the whole thing by pressing down the power button. Anyone else getting this issue? At first I thought it was the soundbar so i've been using it without that but the same issue occurs. I've restored back to factory 4 times now, its getting very annoying.
Wdp1234
Is there a fix in the works for netflix? still as I can no longer sign in, It just keeps booting me out to the netflix sign in/start a free month screen as of today at least. or anyone got it working again? help me..thankyou.
kelchashock
Are you on the latest software version. i've logged into and watching 4k netflix fine. I know there were issues prior to the last 2 software updates for netflix viewing.
UnoBorg
Yeah mines fine too barring the stereo output that we all know abt! but I
play from sony blu-ray player so It's 5.1
Regards
Mark
Wdp1234
i'm on the latest software but i've got the kdl-43w756
UnoBorg
If you look with other TV's as well sound bar doesn't fire up with TV's....Only what I've rad cause I don't use a soundbar....Unless It's an expensive soundbar who want's to use one?
kelchashock
I havent used the soundbar in a while now, but I still get the issue.
Rikachu
Nevermind. Found this site: http://help.sky.com/articles/program-your-sky-remote-to-control-your-tv And used code: 1853 Works great now 😃
