2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
PracticallyGeek
I can confirm with keytone I also get a weird echo/buzz sound after moving around menu. Also with volume around 1-5 the audio comes buzzy or distorted. . .if volume is high enough maybe over 7 the distortion goes away. Thats with my SKY + HD box plugged into HDMI 3
profile.country.nl_NL.title
corpsmaster
I am glad that I am not the only one with this issue.
@PracticallyGeek, what do you mean by volume 1-5? I have the volume set to around 15 and I still can hear the noise. With movies you can not easily hear it, but it is still there.
When you hear the keytones, it is just plain obvious.
@NickCo1979 andy idea if this is on the list to be fixed?
PracticallyGeek
@corpsmaster I will confirm later but at a certain volume my sky output is distorted but after a certain level maybe over 5 it can't be heard. . The sound after the keytone I think may just be the sound effect rather then distortion but can't say for sure
wills_b
Aside from 5.1 issue I haven't noticed any sound problems.
Might be worth mentioning if people are talking about the tv speakers, sound bar, optical, ARC etc
Havent noticed any sound issues after the update on tv speakers. Only thing
is the lip sync issue on ARC and no surround in apps.. otherwise no problem
(with the sound though)
crash007
My Sony 55X8505C tv is turning it self on after few hours this started after the latest update. Has anybody else this problem.
Have you checked the settings? Theres a menu for the tv to automaticly turn
on or off at a specific time of day or timer
profile.country.FI.title
markom80
Doesn't anyone else suffer this bravia sync reboot issue if source is not selected properly? Is there something i could try?
nickbaker66
My 49x8305 turns itself on I thought it was just me as nobody has mentioned it before
And I have not seen a setting to turn the TV on
Twobins
Yes - I've noticed that happens with mine. Still lots for Sony to sort out. I wonder how they would have taken it if we had been allowed to buy the tv in stages with a final payment around October - or maybe later depending on HDD recording being made available. Poor show all round.
