2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
andipr
Any of the Mods/Experts on here know what the next steps are for updates pls?
Just trying to establish if there is a definitive bug fix list or list of enhancements that the devs are still working on.
I know it was mentioned the other day that there will be updates in line with Android OS releases for some time to come.
My concern is if the focus is on the 2016 range that we will be forgotten.
My Model KD43X8309CBU
profile.country.IT.title
rooobb
Remember that Sony during CES committed to upgrade the 2015 lineup to Android Marshmallow, so they will have the same OS of the new TVs
frankie1g
But not same hardware
Sent from my Samsung device
Anonymous
Not applicable
Correct - unless you invent the delorean :wink:
mk1.golf.1983
Our tv No.6 faulted yesterday morning with the same 6 red flashes of it's led. Last time the engineer came around he said that the power lead wasn't pushed fully into it's socket? Ha! He also carried out a factory reset,  so obviously neither of those fixed the problem. Add to that fault I also am experiencing a hdd fault where the tv will not reboot if the hdd is plugged in, it just hangs until both hdd and tv are unplugged and tv is powered on it's own, the drive is fairly new with little usage and shows as good with wd diag tool. The tv has also lost ethernet connection a dozen times since we purchased the original tv although it's been faultless the last few days.
KDL43W755C
frankie1g
That worked fine just add fuel
Honest to God - all I wanted to buy was a new TV.  What I've got is some nearly incredibly clever thing that sometimes works as a normal TV.  Youtube and Catchup are the only extras that my Sony gives me that I use. Not interested in anything else - though that could be becuase I have Sky HD+ box on another TV in another room so not looking to do some of the stuff lots here are trying to do.  But my remote sometimes doesn't work, YouView guide sometimes hangs, Home sometimes doesn't display stuff like Catchup and tells me recommendations aren;t available for some reason, and so on. Not big deals buit irritating.  Are all SMART TVs lkke this flakey on the basis. But when I then read of all the technical stuff being suggested here by owners of the TVs and Sony - I despair.  Too difficult.
All I wanted was a new TV...:(
alfonzobonzo
A-men to that.
mk1.golf.1983
Amen...
Anonymous
Not applicable
@mk1.golf.1983 wrote:
Amen...
Aperson (for gender neutrality)  :slight_smile:
@mk1.golf.1983
Ive reported the network connectivity issues.
Your issue with the tv not rebooting whilst the HDD is connected - im wondering if this is isolated to you only, or are others having this same issue too?? As i cant remember any other posts?
