Hi there, so I've purchased a Sony KD43X8305CBU android TV and have noticed that if it's left on standby for a few hours and presumably goes to sleep I am then unable to wake it through any means whatsoever. Nothing happens when I press any butons on the controller or on the TV itself etc. It means i have to reset it by pulling the plug out. Is this a known bug or some kind of fault?
Thanks
The TV turns off automatically.
Hope this halps
Hi there, I've now turned these sleep settings off. Though surely if it does go to sleep you should still be able to wake it by pressing something on the remote?
Can confirm that even with the sleep timer turned off I'm still getting this issue. After being on standby for more than a few hours you havr to hard reset this by pulling the plug as non of the remote buttons or the buttons on thr TV work. Is this a software fault or could it be a hardware one?
Hi, did you get this issue resolved as I have the same symptoms on a brand new Sony KD-55XD9305. Sony Tech support are investigating the problem, but I thought I might find a quicker solution on the forums.
