Can I connect Any bluetooth Headphones with W955 or W805 Tvs?
dejavus
Hi All,
I have Both TVs listed in the Title and since they both have Bluetooth I was wondering if I could directly connect my Bluetooth headset (Manhattan) However I am prepared to buy a Sony one or NFC enabled one if it will work with the TV. Anyone have any experience on weather this is possible or not.
Thanks in advance.
Anonymous
Not applicable
Hi there
For both TVs (and all the others) - Only bluetooth mice can be added.  See : HERE for more details.
5 REPLIES 5
Anonymous
Not applicable
Hi there
Nobody-in-particular
Contributor
Hi, no you cannot connect bluetooth headphones but, as you state that you are prepared to buy new headphones and depending our your budget, there is an alternative option that you might wish to consider.
MDR-RF865RK Wireless Home Headphones with Noise Reduction
dovydax
can I connect kdl46w905 via NFC or any wireless connection with sony headphones
MDR-ZX770BN ?
Anonymous
Not applicable
Hi @dovydax
Those headphones will not work with your TV.  Headphones need to be wired, either directly or to a wireless base station, like in the picture above.
dovydax
Are u saying that NFC not working with headphones, only Wi-Fi direct?
