Hi can anyone help with a set up issue. I set up my Sony Bravia XR 55A95K without the optional Bravia Cam. Now I want to install the Cam but can't see how to do it. It does not appear in the list of Settings/Remotes and Accessories so I have no way of selecting it to install. I have been through the set up again but this time the set up doesn't ask me if I want to install the Cam. I have done a soft reset and a hard reset and now I am out of options. Before I take the TV back to factory settings and do a reinstall, is there any way to install the cam? When I close the Cam shutter on the top of the Cam, the TV acknowledges that the cam is shut, but that's all. I cannot get it to respond or connect when the Cam is "open".
Hi @jprice126 Just in case you haven't seen it, software version v6.5954 is now available which adds what I already have with v6.5929.
oooh thanks so much for the heads up. I hadn't seen this. I have installed the latest update and the Cam works!!
I have no idea what to do with it yet but that's my next challenge:-)
Thanks again.
The latest software update had resolved my problem. Thanks so much for your input.
