I've been having a recent issue with my Sony bravia KD-49XD8099.
Once I've switched it to standby with the remote, it won't switch back on unless I switch it off at the plug.
Is this a know issue and if so is there any fix?
Thanks in advance
Do not know how I "spoilt it"
sorry! Have you tried removing USBs?
Hi @Hungledink78 and welcome to the Community
You may have done so already but have you checked if you have any other problems using the remote
control or if the batteries are not depleted?
When you try to switch on using the reomte does the illimination LED light up or is the set just 'dead'?
You could try a reset of your TV to see if that helps.
Here are some reset instructions
Hope this helps
Got my fingers crossed but the removal of a usb drive I had connected seems to have worked.
Thanks for the advice 👌
