KD-49X8305C Software update crash 64%
grayhm63
Contacted Sony - all their attempts failed.
I tried installing the latest firmware update V2605 online through TV( I have 150Mb cable), also downloaded the firmware and put onto a USB(tried the two file method also).
Every time, via TV setting software update, the download crashes at 64%(states "An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123).
The usb( usb slot 1 and 2 tried) method also crashes out into reboot at about 64% too.
Downloaded the firmware numerous time.
Any ideas ?
135 REPLIES 135
Simply4Me
Just to report that I approached the update on my 49X83 with some trepidation after reading this thread. Downloaded over WiFi and it worked first time.
Much relieved!
sunlightd
I'm having the same issue (restarts at 65% when installing from USB) with a 50W805C. Can you send me the same instructions?
Thanks,
David
Anonymous
Not applicable
Hi Sunlightd - ive sent you a PM.
TheOneTheGreat
Guess what, same issue. Could I please get an instructions how fix it
Anonymous
Not applicable
Hi @TheOneTheGreat - what model is your tv?
TheOneTheGreat
Quinnicus KD-49X8305C
Anonymous
Not applicable
Hi
Ive sent you a PM with some instructions.
TheOneTheGreat
@Anonymous Much appreciated. Worked perfectly! Quick question thou... my buddy in the States has bricked KDL-50W800C. That TV is in boot loop: SONY logo comes up then 4 flying color dots then it reboots. Occasionally, he says, 'Optimizing apps comes up but then it reaches 192 out of 192 and... reboot. Any help with this issue is very much appreciated.
Sly079
Hi, I'm having the same issue with a 55X8505C.
Can you sent me the same instruction?
Thanks
Roland
Rossdoc81
Hello,
I am having the same problem with my 43w755w. Could you please send me instructions on how to fix this as it crashes at 69% everytime I try to update from th USB stick.
Thanks
Ross
