KDL32S2030 HDMI Connection not live
ALLADIN365-.
I have been given this television and have tried connecting an Amazon Firestick to it with no success. There is only one HDMI socket on the back of the tv ,   Whem I scroll through the settings I can`t see an HDMI  tab to click on !, does this mean that the socket is not connected or is there something I am missing ?  There are such things as AV1, AV2, AV3,  External Feed etc that can be highlighted.  I am far from an electronics wizard but understand basic instructions in my senior years !
Also the remote control unit does not operate the volume on the tv but can be done on the tv itself.
Any information would be appreciated.
3 REPLIES 3
Win_88
Specialist
Hi Alladin,
I found in the manual that the HDMI port is represented in the input list by AV4.
The TV seems to be a bit on the older side, this means that the HDCP version supported by the HDMI port on it could be out dated, causing incompatibility with newer HDMI devices.
I hope that helps
Win_88
ALLADIN365-.
Thanks very much for your reply. Yes it is an older TV, actually 2007. I
will give your info to my brother in law and see if he can sort something,
but otherwise thanks again.
Regards
ALLADIN365-.
Thank you for your reply, I will pass on your comments to my Brother in Law and it will most likely help him to come to a decision on what to do. It is quite an old set as you say so will see what happens.
