Remote Problems
ScreenIdol60
Remote Problems
My Sony KD49XD8099 remote operates intermittently and erratically even after a factory reset. It is driving me insane. Anyone having similar problems or solutions ?
SpookyZeus
Strange, I wonder what the difference is between the old remote & the newer ones? I assume whatever the difference is lays at the heart of the problem and is on the TV set? Either that or just a coincidence & the replacement needs resetting or new batteries. Again strange that it seems to work slightly better than the original.
7 REPLIES 7
SpookyZeus
I had my XD8305 about 2 -3 months before my remote became intermittent, sometimes worked sometimes wouldn't but i just changed the sony supplied batteris with new ones and all became good again.
Hope it works for you
Anonymous
Not applicable
Hi there
I dont have this problem - but after initially switching the TV on, the remote controll can take a minute to become useful though.
Budhi108
It is not about batteries. You are reset your remote when remove both baterries and this is a trick. You can back "old" batteries and remote will work just fine
when remote become crazy just remove both batteries and put them back and everything will be fine
ScreenIdol60
Thanks for your input.
Having changed the batteries, reste factory settings etc etc I returned the faulty remote to the shop I bought the TV from and they gave me an old Sony remote to use as a replacement while they ordered a brand new model.
I tried the brand new remote last weekend and found it worked inconsistently, so this may be a design fault.
I will continue using the replacement Sony remote as it works perfectly and I can watch my TV stress free !
SpookyZeus
What a pain in the backside, I hope you get the issue resolved. Does the shop you purchased the TV have another like device you could try your remotes on, this at least may tell you if it's the remote or the set.
I realise the old remote works on your set but really need to test your remotes on other like set to conclusively prove either way where the problem lies.
Good luck
ScreenIdol60
The staff at the shop tested and proved the original remote was faulty while I tested the new remote which behaved similarly but not quite as bad. The old remote works perfectly so I'm using that instead.
Sent from my iPhone
SpookyZeus
