Solution for Netflix not working
profile.country.GR.title
MiCal1967
Contributor
For those who paid Euro 7.99 and need to watch their movies :slight_smile:
Open ES file Explorer
Go to / Device
Go to System (Open folder)
Go to app (open folder)
Find netflix-ninja-release.apk
Select to execute
Select Install
If a message says you cannot install go to Allow Uknown sources and select On
This will give you a message of Update for Netflix.
Just do it and installation will start.
Then everything will work again.
32 REPLIES 32
Anonymous
Not applicable
Hi @oscarbravo321uk
Thanks for posting this tip about BT Web Protect.  It might help others in the future im sure.
PauloLondon
I just bought the new Sony A1 which uses Android and won't load Netflix or stream via ChromeCast.
I read this solution from another forum and it worked!
Hold down the green power button (top right of remote) for 10 seconds. The TV will power down and then restart with a reset of Android - I was panicky at first as I thought it would reset the whole TV but it just brings up the Android cogs and then a fresh start of all applications - somehow this has fixed the problem and I can now use Netflix and YouTube without any issues!
profile.country.IE.title
seanmcnamee1
After firmware upfrade, power of TV then power on. Netflix should work now. This worked for me. Hpe this helps!
