- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sound out of sync/distorted XH90
Anyone have any HDMI sync problems? Have a 65” XH90 connected to a BT UHD box. All was fine.
However the last week sound (only use TV speakers) now crackles/distorts, and goes out of sync.
Switching inputs, switching TV off/on, gets it back in sync. This happens for recorded programs and live TV via the BT box.
However using the TV apps, Prime, Netflix etc everything is ok.
So tried a new HDMI lead, and different HDMI port and the same result.
So I presumed it was the BT box, however just received a new BT box and it’s the same....
So is the TV broke? Why are apps ok, only the HDMI sockets broke?
Anyone anymore help please
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Please all phone Sony support as well, shops will just swap but we need Sony to acknowledge this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In on my second tv, and have the same issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have tried a forced factory reset today, things were fine for a few hours but now lip sync is way out again, truly annoying.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Glad I didn't bother doing the factory reset so. Such a pity but 2nd tv in 2 weeks going back to the shop and I'm not replacing it with a Sony one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Guys in diferent forum found solution:
Possible fix on 10/17. So I may have accidentally found a fix. Do you guys have the tune-in radio app on the your tv? If so. Uninstall it. And reset your tv (not factory, just unplugging tv and plugging back in). This has seemed to fix the crackles for me as I have now gone a full two days without it. Let me know if this helps! Another user, Drop9Reddit, can confirm this helped fix audio issues as well.
I noticed tune-in kept disconnecting and reconnecting itself to cast on my tv. I tried casting with my Microsoft surface and this prevented me from casting on it. So I uninstalled tune-in. And since then, haven't had any audio crackles. It sounds stupid, but give it a try.
This would make sense on why Sony has no idea how to work around this issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have tunein installed, will give that a go, thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Tried that and working fine. Just unnistal Tunein and unplug TV for 5 minutes. All working fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I uninstalled Tune in app from my TV last night, plugged out TV for 5 mins and turned back on, bizarrely enough it seems to have worked ! So far anyway, all is good with the TV with no lip syncing or crackling sound issues.
Well worth trying for anyone who hasn't yet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same here, I also uninstalled tunein last night, and so far so good, no crackling or lip since issues,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've just uninstalled tunein and switched my tv off at the wall, I'll let you know how I get on, if this works you're a legend! This has been doing my head in. *fingers crossed *
