Un Powered USB HDD on Sony KD49X8005CBU
Costeta
does anyone know if a non external powered (basically a USB powered) USB HDD can be used on my Bravia TV KD49X8005CBU?
Thanks
Regards
Terry
3 REPLIES 3
profile.country.IT.title
rooobb
It depends on how many ampere it consumes, normally under 1TB (and 0,5 A) there should be no problem. Basically the answer is yes
Anonymous
Not applicable
Hi there
If using a USB powered drive, it should be fine using the 2.5" drives.  With the larger 3.5", its best its used via main power adaptor.
Costeta
Hi, Thank you guys. Yes I'll obtain a 2.5" drive and under 1 TB.
Once again thank you for your help
Regards
