C2305 not switching on
Gnair
I bought this product online yesterday & used it just half a day & phew it went off. I tried switching it on back but in vain. It had updated to the latest build version via pc companion also. I have requested for  the replacement from the online retailer. Don't know how this happened.
profile.country.RO.title
_alexdon_
14 REPLIES 14
_alexdon_
Have you discharged the phone completely?Connect to wall charger,charge for 1-2 hours,turn it on.
alexdon
Gnair
I charged it full overnight but still in vain.
_alexdon_
Force turn off the device:
http://userguide.sonymobile.com/referrer.php?region=gb&product=xperia-c#!Turning-on-or-off-the-devic...
After that,turn it on normally.
alexdon
Gnair
Ok the reset key on the back did wonders & switch the phone on. But now the screen of the phone keeps flickering. Also i had installed clean master will this app give any issues. The build number is 16.0.B.2.6.
_alexdon_
Do not use task killers or battery savers,the default one is good enough.
alexdon
Gnair
What about the screen display flickering...
Tejinder
Gnair,
Disable Adapt Lightning Conditions in Display > Brightness. This will solve flickering issue!
_alexdon_
About the screen flickering,really do not know.Have you tried a software repair until now?
alexdon
Gnair
I checked in the settings & just have Automatic brightness option. Didn't find the option mentioned by you.
