ClockWorkMod on locked bootloader
OPGELOST
iGLIDE
Bezoeker
Hello
Is there any ways to install clockworkmod on sony xperia e (c1504) with locked bootloader?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Thommo
No - This is only possible on a unlocked Bootloader
Bekijk de oplossing in de community in het oorspronkelijke bericht
9 ANTWOORDEN 9
Thommo
iGLIDE
Bezoeker
But xda forum says that it is possible
Thommo
where would that be on XDA as I've checked and see that it says it must be unlocked
Vengence
Bijdrager
If your scared about unlocking bootloader you shouldn't be even talking about Cwm
Cwm needs kernel replacement which needs unlocked bootloader
And also what are you planning to do with Cwm on locked bootloader..... Pretty much everything cwm needs unlocked bootloader
iGLIDE
Bezoeker
I'm not scared about unlocking bootloader. My phone says that I'm not allowed to unlock bootloader. I want to install cyanogenmod to boost my phone. There are many ways to install cwm on locked bootloader but not exactly for my phone. For example this http://forum.xda-developers.com/showthread.php?t=2187363
Thommo
So you have read that you can for other models but not for your Xperia E - My Z1 has CWM with a locked bootloader
If interested this thread has a list with links to most thing Xperia E and the nature of your topic
iGLIDE
Bezoeker
Thanks bro I have also one question. Does sony xperia e support otg?
Thommo
I'll go out on a limb here and say yes purely based on that my Xperia Z1, S and Tipo do the latter been a low end entry level phone from 2012 so I would assume the new phones will
Vengence
Bijdrager
Not possible on a locked bootloader... Sorry
There are some ways to force unlock but sim may not work after rom install
Sent through my xperia E with Cyanogen mod 10
