How to connect my phone to my car audio system?
Stanly_CK
I tried to connect my phone to my car audio system with the usb cable but it seems not to work.
Any other idea?
Rickard
Master
I suspect that your car doesn't support "MTP" which the phones internal memory uses as USB connection mode. Try inserting a memory card (microSD) if you don't have one and then set the USB connection mode to MSC under Settings -> Xperia -> USB Connectivity -> USB Connection mode. You car should then be able to access the files stored on the microSD and then phone should be able to charge.
3 REPLIES 3
Rickard
Master
Vengence
Contributor
Yup, put it in mass storage
Stanly_CK
Thanks so much! :smileysmileythumbsup:
