I have updated the latest firmware v15261r and since then i'm getting always the warning notification '?' when it comes to add music to the hard drive the update notification never stops to turn around. It is realy a bug in this version? I have erased everything and i added only one album and i was getting again the warning notification '?' even with just only one album. I also discover that the function 'get music info' not working.
You have done everything. Try to connect an external hard drive and transfer some of your music and check how things going. Anyway I hope to find the solution.
Hi Christopher,
I returned from holiday and found all my metadata had re-appeared. I had to re-link some album information and rebuild playlists but somehow the problem has been fixed. I've been using it for a week now with no problems. The version of the software is still the same so no idea how the problem was fixed.
Thanks
David.
Hello David.
It's nice to hear that. Never again these kind of problems. Let's live a better music days.
My best regards.
Christopher
from Greece
