Just got got the soundbar a few days and it started to give out. It was working a few hours ago but now it doesnt work anymore, reconnect the power lead and its still not working.
Hello verify power supply.Or fuse in the power supply .
Hi cosmingpx8,
Thanks for answering, but I tried changing the fuse and made sure the power supply is properly connected. It still didnt work.
Thanks
Hello verify if you have not broken the PCB tracks, processor, remote sensor.
Did you find a solution to this? As I seem to be suffering from the same problem. Was working one morning then just cut out entirely. No power lights on and have checked the fuse.
Thanks
