Help needed with settings on STR DN1080 Amp
Jbeavis17
I have just set up a new STN DN1080 Amp. It is connected to a (non Sony) HD tv, Sony Playstation 4 and Sky Q box.
I have a 5.1 set up with active sub.
I have used the easy setup but want to get the best sound. Which setting is recommended? Dolby Surround, X, or another..?
Thanks!
3 REPLIES 3
grolschie
Contributor
If you set your devices to bitstream audio to the receiver, I would suggest leaving it set to AFD soundfield. If you have height speakers, you might wish to upconvert using either Dolby Surround or Neural:X.
It's more important to set up your speaker sizes and crossovers in the settings optimally. Even if you have large floorstanders, if you have a subwoofer, standard home theatre advice is to set your speakers to "small" regardless of what auto calibration says and to set your crossover settings at least 20-30hz higher than the lowest supported frequency of the speaker.
grolschie
Contributor
Damnearperfect
That’s brilliant.  Thanks very much.
