Please let me know how to deactivate reject calls with a message because when i am in roaming it outmatically sends message if I touch some where other than red button and SMS charges will be deducted from my balance. So I don't want this facility. Can any one suggest me how to disable this feature.
Hi there,
Try the following:
Settings > Call Settings > Reject call with message > Menu > Reset default SMS app
Settings > App > All > Call app/ Phone app > Clear defaults
Cheers.
The solution that worked for me is to change the message centre number ( deleted the last digit). U can't do it from xperia L, as far as I figured out, but u could change the message centre number by inserting the sim in another fone which supports editing the message settings (Like an old nokia fone 1100, 1110 or any "non-smartfone"). Outgoing messages wil be blocked but incoming text messages works fine
hi,
I tried the steps you mentioned but i when i press the menu option nothing happens .. this is very problematic as automatic messages like this are going to all the people..
i am also facing the following issues:
1. the radio sound quality is not at all good on this handset, however, when at the same location i am using a basic samsung handset the clarity is much better..
2. i have installed the call recorder app on my phone but none of the call gets recorded.. its all garbled.. i changed the audio source setting to "voice call" but it always gives me a prompt "the last attempt to record voice call failed. it can be one of two reasons - either your device doesnt support voice recording or other application is recording at the same time"
Please help..
i had been using a samsung handset for the past two years but this E series handset was appealing but i am dissapointed with its performance malfunction..
would appreciate a prompt reply here.
Thanks.
i use xperia e1 call recorder works perfect for me. These are my call recorder settings
Audio source: Mic,
Audio channel: mono (u may even try stereo it would be better but i have never selected it)
Sound Quality: MPEG4 (3gp is bad to hear)
You cannot disable auto reject calll button from appearing in an incoming call but dont worry at all dude there is a way of locking an incoming call. You need to only install a small application named as "tiny call confirm" from google play store. Its size is also very small and it will never consume your battery.
Your incoming call will be displayed on your phone as shown in the following picture, you need to drag the lock button towards the right and then also drag your normal green button towards right side.. So two times you have to drag to answer a call. This will solve your problem.
Best of luck
This idea of instaling "Tiny call confirm" app really worked fantastic, saved me from further embarrassement that unsolicited reject cal with a message always give me.
Thanks guys
Regards,
I tried Tiny Call Confirm and it really works. Thanks 🙂
