Hello,
I was wondering why my Xperia L doesn't have small apps, But when i google it. It said that this phone comes with small apps. Can someone tell me why mine doesn't. Thank you
This has now been checked by concerned team and Xperia L will receive small apps in a future software update. Unfortunately I don't have any timings for this.
that's odd, do you know how to add/open small apps? tap the task manager (virtual key on the right) > you will see the apps that you are currently running on the right and at the bottom you will get the small apps and a +
Look, There is no small apps
that is quite odd, try to install an app like this
It says "the device isn't compatible with this version." What should i do? There isn't any software update or anything
I wonder if its a regional issue/restriction or if its a typo on that link that you posted, where did you purchased your phone ?
check with either PCC or SUS
In Malaysia, Even small apps have reagion restriction? Wow, just wow.
I hope I'm wrong but there are other low end Xperia lack this feature, so it might be a typo, I hope not.
check for an update (with SUS)
Its a mid-range phone, It suppose to have it. Oh well, i will try the update later. So many apps that i've installed, i don't want them to get lost or something. Hm, thanks anyway
