- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
video keeps pausing
For a few weeks now I have had this problem: video and sound (in particular Youtube vid and BBC sounds) keep pausing, resume when the arrow head is pressed, but then stop again moments later.
First I tried restarting the phone. Then I tried emptying cache. Finally I tried installing a trusted cleaner, but it didn't work on my phone so I uninstalled. I also checked for apparent rogue apps. Then I switched my consuming to another device and hoped an update would solve it. Eventually I factory reset my phone - and still it happens.
Today I went through the apps again, and uninstalled a few I didn't need, and a few I can replace. Still it happens.
I read everywhere that it must be an app, which is my suspicion, but how, without uninstalling the lot, can I tell which is the rogue - or whether there might be another reason.
It looks as though I'm going to have to use my inferior device until upgrade time otherwise - which is about 18 months away!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The options that you have is either to remove the apps starting from the recently downloaded apps and test with each one you remove or you can do a factory data reset without downloading all the apps back again on the device , and start to test with each app you will add if the issue will come back again or not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
go at testing the most recent first. Are they listed in date order
somewhere, so I know which I added last?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No, unfortunately i don't think there is a way for that.
- « Previous
- 1
- 2
- Next »
