App not found......
Sonym4aqa
App not found......
Everything was fine then suddenly i noticed three of mine apps icon was changed and whenni tried to open it says app not found...
Tried to look for sd card apps in setting but still nothing helped...can u guide me please
6 REPLIES 6
Uliwooly
@Sac3
If the apps were on the SD card and you unmounted/removed the SD card the apps will be gone, to get them back and/or remove the blue icon, you will have to re-download the apps > move them to the SD card.
Sonym4aqa
How cn i remove the icon
Sonym4aqa
I can just see add to home screen
Uliwooly
@Sac3
follow my above suggestion
DarkoDM
Open settings /apps, find sony xperia launcher (or xperia home), and clear cache, you could also delete data, and thats it.
Matt-C
Having a similar problem with an XPeria M4 Aqua, I've Googled it and had no luck finding a solution. I hadn't unmounted my SD card when the apps disappeared. I tried to clear the data for XPeria Home and I restarted the phone a number of times, neither of which helped. Problem is, I can't reinstall the apps now because of a lack of storage space. I had deilberately stopped updating them to save space but I can't download an older version now and don't have enough space for the latest versions. One thread suggested I unmount then re-mount the SD card which I tried and have probablly lost the apps for good.
In the unlikely event that they can be recovered, any tips would be appreciated.
