Camera button not working
matan299
On diagnostics it works but in the camera app it doesn't work, it won't take pictures and I can start the camera app with the camera button but it won't take pictures with it.
Uliwooly
@matan299
In other words the physical camera button has "never" worked? if that's the case return the phone.
12 REPLIES 12
Ashroft98
Enthusiast
Maybe there's a glitch elsewhere in the app Try this Go to Settings > Apps > Scroll Down until you found Camera app > Tap on Clear Cache,Clear Data and Force Stop > Restart your phone See if the problem is addressed after doing the steps. Hope that helps!
Phy
Legend
Legend
Does it work on safe mode?
How to boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
matan299
Tried clearing the cache and data, force closed it, rebooted the phone and no help still won't take pictures...tried in safe mode doesn't work and i tried clearing the camera app in safe mode then reboot and still no help. Slightly_frowning_Face
matan299
The button has to be lightly pressed to focus then a harder press to take the picture...am i right
Ashroft98
Enthusiast
Yeah that is correct
Looks like you need a software repair
Install PC Companion > Connect your phone > On PC Companion press Software Update > Press on a small blue line "repair phone/tablet" > wait for repair
See if theres improvement after that
matan299
Ok i'll try that later, few minutes ago I was fiddling with it and found out if I very lightly put my finger on the button it focuses and stays focused until I press the button to take the picture so I think that the button is screwed.
Uliwooly
@matan299
That's how the camera button work, it's a 2 step button, the first stop is to focus > second stop is to snap the picture, I don't understand the problem.
Uliwooly
@matan299
matan299
I understand that it's a two step button but I don't feel the first step only the second one. Yes I bought it like that last monday, I noticed it instantly but I was thinking maybe I have to enable it or something like that so it didn't bother me that much, but now its pretty frustrating cause I always used Sony phones and could never believe that Sony would ship out a defected phone.
