Connect a speaker by wire, use phone microphone?
ramendik
I feel the max volume of my phone (Sony M4 Aqua Dual) is too low for use as a speakerphone in a car. But I do not want to get a full Bluetooth device, I'd rather just get a simple speaker.
However, it seems that when I attach a speaker jack, the internal mic is disabled too.
Is there a way to have the phone use the internal microphone with an external speaker?
3 REPLIES 3
xavinux
Enthusiast
Hi @ramendik
Can you try to attach a speaker running your device into safe mode an check if the internal mic works:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
I'm at disposal for any question.
Best Regards,
ramendik
It turned out that the problem was with the connector I checked it with. With a different connector, the phone detects the speaker as "headphones" and keeps the mic on.
xavinux
Enthusiast
Hi @ramendik
Glad to read that your problem was solved.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
Best Regards,
