Hello,
I just bought the Xperia M4 dual and in the Contact app there is a bug in email field. When the email contains something like 123@, the tree digits is replaced by the whole email itself. I tested with email values
- test12@gmail.com : displayed as test12@gmail.com
- test123@gmail.com : displayed as testtest123@gmail.com@gmail.com
- test00000@gmail.com : displayed as testtest00000@gmail.com@gmail.com
The pattern is starting from three digits before @, all digits are replaced by the whole email string.
Anybody got the same problem?
I just got information that the issue has been identified and a fix will be integrated into the next software release.
Could you please send me your details in a PM, and I will forward this.
Include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
IMEI nr:
Contacts app version:
You can see the version of the Contacts app if you go to Settings > Apps > All > Contacts.
Hi @misha17,
Thanks for reporting this. I will forward this internally and update you as soon as I know more.
UK Post code display error. Any numeric part of an address is inserted into the postcode display line. When go into edit mode, it is displayed correctly. If the POST code is typed without the middle space, then no number is inserted. E.G 7 main road, SN10 5PB becomes SN7N105PB. My M4 software is uptodate
Hi @TS0,
This has been fixed in the latest software version. I can see that you have registered your phone's IMEI on our website and it seems that the latest software version has not yet been released for your phone. Software availability is something that depends on country and/or operator so I can unfortunately not say when it will be available for you phone.
