Hi @johnnyboy1963,
Welcome to the community.
You can customise what happens when you connect to your car by using the Smart Connect app. You can add an event so that when you connect to your car, your ring volume is turned down, and when you disconnect from the cars bluetooth, it will be turned up to normal.
Hi @johnnyboy1963,
Thanks Cameron, this has solved the problem.
