My error was the home button is hidden when keyboard is opened for message, input something in web browser...
I've reset the phone but it can not be helped :(, please help me. Sorry, my english so bad.
Did you perform a factory reset of the device? Did you install any applications/restore any kind of backup after this? If you did install some applications, could you try to boot the phone into safe mode to see if same thing happens?
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
I have access to safe mod but not anything unusual appearance but my home buttons appear normal again, when I reset my problem back. Thank you for your reply.
Your problem it's caused by a third party app, which app? you will have to uninstall one by one until you find the culprit.
Thank you for your help, my problem is solved :). Thank you.
Glad to hear! Could I ask which app that caused this behaviour?
My error derived from software EasyTouch(Classic and Holo version), its setting causes this error. Go to Settings -> General -> uncheck SmartHide, my problem was solved.
Thank you for the information! :smileysmileythumbsup:
