Good day
Just received a new M4. The display auto-rotate function does not work. I have diagnosed the accelerometer under the test menu, but fails.
What could be the problem? It's not working out of the box
Br,
Khovi
In that case, it sounds like your phone needs to be examined by a technician. I suggest that you contact your retailer or your Local support for further information about how to proceed with this in the best possible way.
Have you installed any applications or similar? If yes, you could always try to boot the phone into safe mode:
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Otherwise, I do suggest a software repair via PC Companion before you contact the seller for further assistance:
http://support.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
Follow the instruction that appears in the program and do not connect your device until this guide tells you how to connect it.
Hi
I hav not installed any apps. This behaviour was seen out of box.
I have:
1) Performed a factory reset and tested
2) Restarted in safe mode and tested
3) Updated/repaired the phone SW and tested
None of the above helped
Br/
Khovi
Hi
Thanks, I have returned the device to the seller
Br
