Hello, I set a theme a while ago on my phone and now just want a plain black background on my phone. I can't find an option to remove or disable the theme.
Does anyone know how to do it?
Thanks
Hi @Pipingmad,
Welcome to the community,
I can advise that the information @uliwooly has provided is correct, you will always have a theme running on the device, if you want to change the Wallpaper, you can do so manually and if you want it black try downloading a black theme or simply a black wallpaper.
To manually add a wallpaper
Apps > Settings > Wallpaper > Choose Home Screen > change the wallpaper.
I hope this helps.
