I do not suggest that you submerge it completely underwater. You can find more information at the following link:
http://support.sonymobile.com/global-en/xperiam5/userguide/Using-your-device-in-wet-and-dusty-condit...
Yes you can Faiz. But, before u take to the bath, please check your phone both front & back cover lit..
If u found any loose in side of the closed lit, it is sure that water can pass through the hole & u device will get damaged...
Also, after u have performed waterproof test, clean your phone. If not, there will be steam on your back camera & camera will be blured..
Here is the link which performed waterproof test.
