mobile shows " charged " even when battery is only 81% charged
Yeshu1
My mobile shows green light and also shows "charged " when it is only 81% charged and does not even charge further, I am using the original charger and even the power supply is sufficient.
Thommo
It could be that your battery needs replacing - It may give the feedback that it's charged as it thinks it is when as you say it is not fully charged - you could try performing a battery test via the diagnostic settings
2 REPLIES 2
Thommo
Yeshu1
Thanks a lot
