Why / How I don't know... The Ring Volume got Turned Off.. Media & Alarm Volume, Bar is all the way Up.. Ring Volume is Blank, No Sliding Bar (???).. How can I correct this.. Only way I knew of an Incoming Call, the Phone Lit Up, No Ring .. Likewise with Incoming Text (number beside Text App)... Help Appreciated, Cheers Thanks
Hi @NorPlan,
As @nolramlb mentioned, do you have the Do not Disturb-mode active? Swipe down the quick settings to make sure it is turned off. I'd also recommend you check under Settings > Sound & notifications > Do not disturb > Automatic rules and make sure that no rules here are active.
Are you able to lower the volume? If so, press the volume down button until the sound is disabled. Then try increasing the volume using the buttons again, are you able to increase ring volume?
Hi @NorPlan,
Didrik... Thanks for the Comeback.. Beyond Me but Somehow Someway the Do Not Disturb was activated.. All is Good, Bells are Ringing...lol...
