ChappyLV
Screen died!
Hello!
Reecntly changed lcd on my xperia m4 aqua!
Worked fine for 2 mintes. When i was unlocking patters screen went black, thought maybe locked itself up. tried to unlock it! I could feel the vibrations and sounds that i am typing my code but the screen is black. Thought maybe display died. Opened it up again. Put on old display and the same problem. Phone works but display not showing. Tried reinstalling android. Didnt work.
What could be the problem and what could be the cause?
Uliwooly
You might want to post it there on that website or on ifixit or XDA Forum
9 REPLIES 9
Uliwooly
Check if the ribbons are properly connected, also, how did the prior screen stopped working? water damaged? dropped? etc perhaps the motherboard it's damaged
ChappyLV
i dropped the phone from 30cm height and it cracked, working fine but glass shattered! after about 30mins i accidently sqeesed it or smthg and lcd cracked and had loose connection. I ordered a screen on ebay and asked my electricion friend to switch it. He ran into this problem. i dont have glue anymore and he tried putting old screen on and it did the same. Touchscreen working but display not!
Uliwooly
It might be something other than the LCD, maybe something like this
http://www.mobilerdx.com/2015/03/sony-xperia-z3-display-lighting-problem-repair-solution.html
ChappyLV
Good thinking! will try that in a minute! only problem is i dont have any glue pads to put the cover on again if it works! any suggestions? Another problem is i dont understand... should i power the phone when i make the connection?
ChappyLV
i just understood what to do... shouldnt it burn the whole chip next time if it does that again?
Uliwooly
ChappyLV
posted this on ifixit! Thanks for your suggestion!
Uliwooly
Keep us updated
ChappyLV
nothing yet from ifixit...
