Signal/Sim/Network Hardware Problem
720
Signal bar increases and decreases all the time, after a while the device will auto shutdown and has to be rebooted with a cable charger.
If I use the device without a simcard, the device works perfectly fine. Is this a network hardware problem on the M5?
Any solution?
5 REPLIES 5
Uliwooly
@720
Test a brand new SIM card, if you experience the same issue, it's most likely a hardware issue.
720
Currently using the simcard on different device, no problem at all. So what hardware issue is this? Is it repairable? I dont have warranty anymore.
Uliwooly
@720
I don't know what it could be, I'm sorry.
720
Does anybody know what kind of hardware problem im facing, so that it will be easier for me to explain to the local support centre.
Jonas
Master
Hi @720,
I'm so sorry to hear about your phone. Slightly_frowning_Face
A trained technician at an authorized service centre will examine the phone and will be able to tell you what part(s) have to be changed after the phone has been examined.
I would recommend that you get in contact with your Local support team and they will assist you with arranging a repair!
