Sony xperia M4 aqua selfrestarting ?
Gavriil
My phone have been bought on 5.01.2016 and now it shut downs from him self and he restarts himslef .
Is it softwear problem or is hardwear problem ?
Gavriil
Thanks.! I have repaired it .It was the SIM card .My card was cut from micro to nano and it made problems .
4 REPLIES 4
Uliwooly
@Gavriil
Hard to tell, remove the SIM and SD cards > check if the phone restarts by itself, if it doesn't then you have a faculty SIM and/or SD cards
if it does > repair the phone with PCC > if you don't experience the same restart > reinsert the SIM and SD cards
software repair
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
if it does > contact your Local support
Christofer
Champion
Hi @Gavriil,
Ulliwooly's suggestions are good ways to troubleshoot this. I'd also suggest that you test your phone in safe mode before doing a software repair if need be.
Gavriil
Christofer
Champion
Thanks for letting us know! Slightly_smiling_Face
