Hi @joelenvoyage,
Welcome to the forum!
What exactly is happening when you attempt to connect to a network? Are you receiving any error messages? Can you connect to any other network with your device?
I would suggest that you first try forgetting the networks in your phone followed by connecting to them again.
Hi joelenvoyage,
Can you please boot the device in to safemode and let us know if the issue continue?
Its possible that Mcafee was blocking the connection and has been doing so for the past few days. It may be worth checking it when you access other Wifi connections.
