Won't charge to more than 83%
Bayern
My mobile phone won't change more than 83%...even i leave it on charge more than hour...
I tried safe mode
But no difference...
Please help me...
12 REPLIES 12
Lord_viridis
What if you turn it off?
Jonas
Master
Hi @Bayern, welcome to our community!
I'm sorry to hear about your phone. Slightly_frowning_Face
As @Viridis recommended, try charging the phone while it's turned off and see if it continues to charge after reaching 83% battery level.
Are you charging your phone using a USB port on a computer or a wall socket? If you are charging through a USB port, could you try connecting the phone to the charger that was included together with your phone to a wall socket and see if you experience the same behaviour, either when the phone is turned on or turned off.
If you have another original charger and cable, could you trying charging the phone with either of these? If you don't have an extra charger or cable, if one of your friends, colleagues or family members have an Xperia device you can ask them if you can borrow their charger!
Let us know how it goes! Slightly_smiling_Face
Bayern
I use wall socket charger....
Before 2 weeks it was changing for 95 %
But now no...
Once I turn it to demo mode
After that this problem began
Bayern
Viridis
Same thing...
Bayern
Jonas
I'm using a 2.1 ma original charger
Jonas
Master
Hi again!
Is the demo mode currently activated in your phone? If it is, could you try turning it off and see if you can charge the phone past 83%?
To turn the demo mode off, open up the Phone application and type *#*#*73556673#*#*.
Is there any change after you have turned off the demo mode? If you still can't charge the phone over 83% with another charger / cable, I'd recommend that you perform a software repair using Xperia Companion.
This will delete all data stored on the internal storage in the phone so it's important that you backup the data before starting with the repair.
Keep us posted!
Bayern
Ok... Thanks jonas i will try this and poste you what happens...
Bayern
Hello again...
No changes...
I will try deleted cached data partipation and discharge my phone until it off
And charge it...
Bayern
No demo mode... Because I made a factory reset...
