Dunc.. uliwooly gave you the link where all the info is available. It clearly states that you first need to check whether bootloading is allowed in your device. If it is then you follow the steps as given there. There is already a disclaimer that standard users should not be trying this. Simply put, the bootloading unlocking is allowed but those who do it of course do it at their own risk. It is allowed but i guess not recommended and ur warranty may/will be void
suggest you do it with someone elses M first ... not mine tho
http://unlockbootloader.sonymobile.com/supported-devices supported devices list does list the M which is the C1904/1905.
OTG not working on xperia m dual c2004
i conneted otg cable to mouse and several pendrive its not working
its working perfectly on my nexus 7 tab
plz anyone reply wheater otg works on xperia m dual
Yes OTG does work on the C1904 Xperia M and should work on the dual too. See that you are using the right cable as there were problems with some cables not being configured the way the M wants them to be. Sony should ideally have provided an OTG cable to avoid confusion.
I downloaded the bootloader and now my phone doesn't restart. It keeps showing the xperia start screen flash but never starts! Help me.
