Xperia M dual not charging
budde
Hi everyone,I bought my M dual 2 weeks ago,and I was very satisfied with it until yesterday.Now it isn't chargingl.I tried using another cable and connecting to my PC,but it doesn't work.I tried turning it off and charging it.When I do that,the LED lights up,and it shows that phone is charging.But when I turn the phone back on,it hasn't charged at all.I have also tried that power button+volume up button trick(found on a similar thread),and it still doesn't work.Any help is welcome.
P.S - There are no sony service centers in my country,so taking it to a service center is out of table.
5 REPLIES 5
goelaakash90
Do you have any other phone which you can charge using the charger of this phone (M Dual)?
If yes, then try to charge and tell whether it charges the other phone or not.
And you able to transfer files to your phone from computer?
ankitrock
Same problem in my mobile plzz fix sony this problem
Uliwooly
Connect your phone to a wall charger > press and hold power & volume up for 10 seconds > let your phone charge for 2 to 3 hours, even if doesn't seemed that its charging
Mirage126
I did this much... but what to do next?
Kushagravaibhaw
HELLO,
 MY XPERIA M DUAL IS NOT CHARGING.
AFTER HITTING THE GROUND.
THEN I BROUGHT SCREWDRIVERS FROM MARKET AND OPENED THE CIRCUIT AND TRY TO SEE WHAT IS THE ISSUE BUT I FAILED AND REASSEMBLE BUT NOW ITS TOUCH ALSO NOT WORKING.
PLEASE JUST SOLVE MY CHARGING ISSUE.
PLEASE  HELP........
 THANKS.
