xperia m dual wont turn on
ROZWIĄZANE
tech
Początkujący
i was messaging on phone and the screen light went off . pressed the side button but it doesnt turn on and even tried power and volume up button but it doesnt respond, but wen i kept my phone on charging it charges shows led light but doesnt power on ,,what to do ?? help pls..
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
Wyświetl rozwiązanie w oryginalnym poście
8 ODPOW. 8
_alexdon_
alexdon
Uliwooly
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
tech
Początkujący
Thanks for the solution.. I took my mobile to service centre and now it's working perfectly.. Next time any problem occurs will try the solution you gave... 🙂
_alexdon_
Good.
alexdon
VishalRatan
Początkujący
Thanks for the useful suggestion. My phone too worked with pc companion phone repair option.
One thing to mention, please don't install any theme or unknown antivirus on system when RAM is low, it will again cause same issue.
giasuddin
Początkujący
I have selected a snow theme and applied it after download from 'sony select' but just then my xperia Automaticaly turned it off and on again and then cosmic flow is going on the screen but does not open the device, what to do?
giasuddin
Początkujący
My 'xperia c2004's is also fulfill with many apps in internal memory and available 260 mb but I'm facing problem with the device that if I power it on then a cosmic flow going on the screen again and again but doesn't open it. What to do? Plz help..
Priyank_5258
Początkujący
I have selected a winter theme and applied it after download from 'play store' but just then my xperia Automaticaly turned it off and on again and then cosmic flow is going on the screen but does not open the device, what to do?
Please Help me.
