Hello,
A friend of mine bought me an Xperia M5 while in Singapore. It's a e5653.
Unfortunately, it's not fully compatible with the LTE bands we use here, in France. The compatible model is the e5603, according to the M5 white paper.
Are the differences between the 2 models only software relater or are hardware related? Is there a way to flash the phone and turn it into a e5603?
Thanks,
LTE band 1(2100), 3(1800), 5(850), 7(2600), 8(900), 20(800) - E5603
LTE band 2(1900), 4(1700/2100), 5(850), 7(2600), 12(700), 13(700), 17(700), 28(700) - E5606
LTE band 1(2100), 3(1800), 5(850), 7(2600), 8(900), 28(700), 40(2300) - E5653
You can flash different firmwares BUT it won't change the 3G nor the LTE frequencies as this are hardware dependant not software.
To the best of my knowledge, this is hardware related when it comes to the LTE bands and not software related.
Hi Benoit,
It depends also from the provider you have in France. The type of phone you mention does NOT support the LTE band 20 (800 Mhz), which all French providers support) but it DOES support the LTE band 7 (2600 Mhz, all providers in France support this band). To have a better 4G coverage with this specific model you should sign up with Bouygues, as they are the only one to also support LTE band 7 (1800 Mhz)
Bouygues | 800 | 20 | FDD | Jul 2013 | N/A | 10 MHz [8][95][96][97][98][99] | |
Bouygues | 1800 | 3 | FDD | Oct 2013 | Jun 2014 | 15 MHz in use [8][97][99][100][101] Carrier aggregation of 30 MHz (CA_3A_7A). | |
Bouygues | 2600 | 7 | FDD | April 2013 | N/A | Jun 2014 | 15 MHz [8][97][99][99][100][102][103] Carrier aggregation of 30 MHz (CA_3A_7A). |
Free | 2600 | 7 | FDD | Dec 2013 | Dec 2013 | 20 MHz [8][103][104] | |
Orange | 800 | 20 | FDD | Aug 2013 | N/A | Jul 2014 | 10 MHz [8][95][105][106] Carrier aggregation of 30 MHz (CA_7A_20A). |
Orange | 2600 | 7 | FDD | Nov 2012 | Nov 2012 | Jul 2014 | 20 MHz [8][103][106][107] Carrier aggregation of 30 MHz (CA_7A_20A). |
SFR | 800 | 20 | FDD | Jul 2013 | N/A | Oct 2014 | 10 MHz [8][95][96][108][109][110] Carrier aggregation of 25 MHz (CA_7A_20A). |
SFR | 2600 | 7 | FDD | Nov 2012 | N/A | Oct 2014 | 15 MHz [8][103][109][110][111][112] Carrier aggregation of 25 MHz (CA_7A_20A). |
More info can be found here: https://en.wikipedia.org/wiki/List_of_LTE_networks_in_Europe
