Hi All
I have recently taken some photos off my Arc and put them onto my computer but think I have messed up my phone somehow in the process.
When I used to take a photo it appeared in a gallery on one of the home screens on a kind of rotary thing with all my other photos but I have just found that now when I take a photo it doesn't show on here anymore. The home screen that used to show all photos is completely blank.
The photos are being taken though, and I can find them by pressing the Media widget and then choosing gallery.
Is there a way of having my photos back on the rotary thing on one of my home screens?
Sorry if this doesn't make too much sense, hopefully you'll know what I mean.
Thank you.
hmm..glad i could help
make the thread answered ok..
so that any person facing the same issue gets the answer
go to settings > applications > manage applications > all.
then scroll down to photos and videos..ta on it ie select it and click on clear data..
see if this helps..
Thanks for the response. Unfortunately this didn't work. I cleared the gallery application too but still nothing.
Do you think I have accidentally deleted a file?
ok long press the photos and videos icon and delete it ie dragging it to the bin..
then long pres on home screen and select widgets
then scroll down to photos and videoa and add it..
if it says already added..
then clear the data again and see if u can place a new widget try it..
and no its not easy to delete system files so m sure u dint delete any file
just try the above..
You, my friend are a GENIUS!
All I had to do was add the photos and videos widget to the home screen! I had looked at adding a widget to the home screen before but I didn't realise that I could scroll down the list!
Thank you so much I was really worried that I'd buggered up my phone.
Cheers mate.
Will do.
