- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Can't receive SMS messages
Seems to be a common problem, but I haven't found a proper solution.
I don't receive any text messages sent to my number. Everything seems to be ok in settings, Phone is brand new, i's updated with latest software and I have enough memory for receiving messages.
Any solutions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try Settings - Apps - All - Messaging then tap clear data and see if that works - If not you may have to reset your settings via the backup and reset - Not the factory reset, There is an option for settings reset, This will not delete anything
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, try the following ....
Switch off phone, remove and reinsert SIM card, then switch phone again.
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Guys,
I suggest trying to remove the SIM from the handset and testing with another SIM card.
Once you have tested with the new SIM simply pop your SIM back in to the device and then get a friend to send you a message.
If you receive SMS from friends who do not use an iPhone but none from the friends who do use an iPhone, then this may be related to iMessage, to solve this issue simply ask your friend to disable iMessage when trying to message you.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can't receive text msg from iPhones answer if your friends have iPhones tell them to turn of I message before sending you a msg that's if yours is an android phone hope this helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I can get messages on my phone from everyone but Verification codes from twitter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Mine also..
Can send sms.. But cannot receive any..
Sony XZs
