Cannot connect to PC
ROZWIĄZANE
Nie dotyczy
I am trying to connect my X10 mini pro tp my pc but it keeps saying it cannot find the phone. It is connected via the USB cable. Do I need to change my settings? No messages come up on the phone at all. Nothing will download or update. Any suggestions?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
uliwooly-wooly
Legenda
so you already re-installed PC Companion on your computer
then you restarted your computer
then you turn off/on your phone
then you connected your phone to your computer
the LED turned on (green)
and after few seconds/minutes that the phone was connected to the PC nothing came up to mount your SD card?
Wyświetl rozwiązanie w oryginalnym poście
12 ODPOW. 12
uliwooly-wooly
Legenda
I don't have any Xperia running 2.1 w/ me but
go to settings -> sony ericsson -> connectivity (do you have that option)?
also try a different micro USB cable or USB port on your PC
Nie dotyczy
It is Android 1.6. I should get a message 'Connect Your Phone' but it doesn't appear. I have tried 3 different cables and 3 different PCs but to no avail. When I drag down the screen it just says 'no notifications'. There isn't a connectivity function, only wireless.
uliwooly-wooly
Legenda
when you connect the phone to the PC does the LED light turn on (yellow, orange, green)?
Nie dotyczy
Green.
uliwooly-wooly
Legenda
that's good, ok so there isn't an issue with the usb cable nor any of the USB connectors
re-install PC Companion, restart your computer and that should do it, it will look for the drivers needed
don't forget to mark the correct and helpful answers Slightly_smiling_Face
Nie dotyczy
No still nothing. The 'Connect Your Phone' doesn't appear.
Do I mark it incorrect and unhelpful:smileysad::smileysad::smileysad:
uliwooly-wooly
Legenda
uliwooly-wooly
Legenda
Also go to
settings -> storage
what do you see?
Nie dotyczy
Getting closer. The drivers installed but the phone screen is locked on the battery recharging page. I will try again later, but it is looking good. The big difference was switching the phone off and on. That seems to have done it. I have the phone on charge and will let you know if I win!
