Good day everyone,
I'm a newbie around here. I just bought myself SE Xperia Arc just today. I would like to inquire if anyone could kindly help me out if I can d/load this type of application or does my phone support it? If there ia any android application website which I could use for chinese language.
Thank you for your guidance & advice in advance...
Cheers!
Hi, try this first before searching for apps .... In messaging app, long press the 'Write message' area, there will be a popup, select Input Method, then Chinese Keyboard.
go to settings > language and keyboard..
and select languages..
chinese will be the last option
its wriiten in chinese only and some other language symbols also..
Oh, did I misunderstand the question?!
Schnapps121 did mentioned 'INPUT', first thing came to mind is messaging!
the reply you gave was my second suggestion :smileygrin:
its ok..
if he needs only messaging in chinese then your suggestion..
if he needs to ful phone chinese then mine :smileygrin:
Just wondering .... will input be chinese (for messaging app) if your method is chosen?
You are the mod:-D u shud know..i will not check myself..if i couldnt restore it back to english i will be in a big trouble..you check.and let me know:o
If you are not able to change it back to English, I can offer you some help.
lol i checked it
yes you have to change the input method to be able to write in chinese
also..."new message" was wriiten in chinese only..
and when i selected chinese as a input method..a pop up appeared but since it was in chinese i dont know what it was
