Hi guys! I was wondering if it's okay to charge my phone for 8 hours like overcharging it?
Not applicable
Because my friend told me that it is good for my phone's battery because recently, it is starting to act up. Like I just finished charging it then by an hour without using it, it drops from 100% to 95%. Any suggestions to prolong my battery's life? 🙂 Thank you in advance!
Sam
Legend
Legend
With this operating system this does not work as the handset will stop charging once it reaches 100% and will not start again till it drops to the low 90's. This is to prevent over charging which could impact the life of the battery.
5 REPLIES 5
Sam
Legend
Legend
slimshaddy
Hero
hii sam..is it same for the arc also..??
i mean the green light shows even when the phone is 100% charged,,is it normal..??
Sam
Legend
Legend
Yes this normal for this model as well.
slimshaddy
Hero
hmm thanks...
Not applicable
I think it will not have any effect because li-po or li-ion batteries don't have the old memory effect.
