I enabled Facebook Inside Xperia and I noticed that it automatically detects my Facebook friends and links them to my phonebook. While this feature may be useful for some, it isn't for me. I don't want to have my Facebook friends automatically linked to their phone numbers on my phone book.
All in all, I just want to disable Facebook's auto-detection on my contacts.
P.S.
I already turned off syncing on Facebook Inside Xperia™ but it's still there on my contacts. (See below)
I also have set the Facebook application to NOT sync my contacts already so I don't know what else to do.
Hi
settings> applications >manage app> all> facebook> clear data
settings> accounty and sync > turn fb sycn off
If the above doesn't helps
do this > contacts > menu button> backup contacts > memory card >
after that settings> applications> manage> all > contacts storage > clear data ( it would delete all contacts )
now restore your contacts from sd
contacts > import > phone> memory card > select vcf file > import
Hi
Cleared the data on "Facebook". No go.
FB Sync is already disabled and still no go.
I believe the Contacts one is related to the Facebook Inside Xperia instead of the Facebook application one though?
oops, try second suggestion i gave
Great! Thank you!
