When I hold and press my home screen it brings up the menu to change my wallpaper, I can move the widgets around in the 4 corners of my Xperia Mini 10 but I want my clock back in the middle of my home screen.........any help please?
From what you have posted, I think yours is a X10 Mini.
From Homescreen, press MENU button>Arrange Widgets>Add Widgets, you should be able to add the clock.
-Thread moved to the correct community -
tap and press ur home screen> widgets>select clock>it will appear on ur home screen> tap and hold ur clock to move it at any position on the screen
Thanks, I can move the widget around from page to page or to any of the 4 corners on my home screen but I want it in the middle of my home screen and it just comes up with the wallpaper options still.
Thank you, it has worked
Great!
