Problem in Updating software to 2.3.4
Not applicable
I have encountered problem during Update it says this
Please help me with this problem SE support team.
gwhispererz
Champion
Hi, either you update with another PC/Laptop or use SE Update Service instead.
Here's the download link, http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe. Launch it and follow on-screen instructions.
14 REPLIES 14
gwhispererz
Champion
Not applicable
ok i will try this.
if SEUS doesn't work, then turn off your antivirus and/or firewall
if that doesn't work then
restart your computer in safemode then run PCC or SEUS (restart then press F8)
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Not applicable
I waited for about 45 mins. but downloading still stuck in 184.7 MB. what should i do ?
Not applicable
Nevermind i think the update is successful i should wait for another 30 mins. instead :smileygrin:. Thanks so Much! appreciate your help Slightly_smiling_Face have a nice Day
did it worked?
Not applicable
yes SE Update Service worked !
Not applicable
update was successful but when i try to play Crash Bandicoot it says that i need to download something.
